M oil pump and cam removal
Gary Sayre
04-05-1999 16:36:39
HELP!! I am rebuilding a farmall M engine(first time for everything!)I need to have the block bored for larger sleeves. I have everything out of the block except for cam shaft and oil pump. My M has a pin through the top of the shaft. How do i get it out!?! Driving me crazy! No room for tools in there. Any Help much appreciated.
C.Fitz
04-06-1999 23:33:36
 Re: M oil pump and cam removal in reply to Gary Sayre, 04-05-1999 16:36:39
The oil pump has to be taken off first by the 2 mounting bolts and it should pull down as it unmeshes with the cam-shaft gear. To get the camshaft out you have to take off the front timing cover, which involves a whole lot of work. the radiator needs tocome off, the front crankshaft pulley needs off. Then unbolt front timing cover.You'll also need to pull rocker arm ass.; pull lifters out, then take that tappet plate off the side of the block and lift your tappets out from off the cam-shaft. Then you can unbolt the cam-shaft timing gear bolts and the cam-shaft should pull out with the gear attached toward the front of the tractor. I might of forgot a few things but that should get you in the ball-park. Have fun.
RED Blooded
04-05-1999 18:19:06
JUst out of curiouity what do you plan to do with your M.I am mainly concerned why you need to bore it out for bigger sleeves.As for the oil pump iI think that it just bolts in there,Been a while since I rebuilt on myself so I dont remember a pin for the cam.
