Re: Farmall H stuck in gear(s)?
Dave_Id
12-24-2001 11:39:29
Bob M is probably right. You'll need to rem. pin, spring and convex flange on your gear shift lever. Then you can see what you have. This will be a good time to check for wear on your shifter pawls. If you have too much, you may want to build up with a hard weld and refit.
