Re: Will 6 volt generator work on 12v
The Red
08-26-2001 11:11:41
Afraid not. You will have to get the generator rebuilt for 12 volts. A rebuild with a new regulator should run around $125-150.
cornfused
08-26-2001 18:59:28
 Re: Re: Will 6 volt generator work on 12v in reply to The Red, 08-26-2001 11:11:41
Red, the rebuild shop down the road does not agree with you on this one. He hooked up the one off of my H and it charged 14V. He claims a regulator change will do it. I don't know for sure but he has been in the business as long as I can remember.
TomH
08-26-2001 19:33:23
 Re: Re: Re: Will 6 volt generator work on 12v in reply to cornfused, 08-26-2001 18:59:28
Someone else (I think it was Les Repair) said the same thing about changing the regulator a while ago. He explained that the generator produces a certain number of watts, you can have more volts and less amps, or vice verse depending on the regulator.
cornfused
08-26-2001 18:56:14
