Will 6 volt generator work on 12v
Michael
08-26-2001 11:08:39
Can I just change the regulator and still keep my 6v generator on my Super A if I convert everything else to 12 volt. Though I have read in the past that it will not damage the generator.
Burl
08-27-2001 05:55:22
 Re: Will 6 volt generator work on 12v in reply to Michael, 08-26-2001 11:08:39
My (gasp) JD B has a 6v generator with a 12 v regulator on it, and it works just fine. My Farmall 240 has the same setup, and works fine also.
LarryG
08-27-2001 04:12:34
...so if a 6 volt generator can put out 14 volts, why have so many people gone through the trouble of replacing them with an alternator? Kind of makes you wonder why you can't get somethin' for nuttin'..... ..
gene b
08-27-2001 04:02:26
if you know someone who can make a 6v gen put out 14v this guy will make THOMAS EDISION look like a dummyanyone who has a sceince book or ask any teacher how to get D.C. voltage from a generator you will understand why did they make new generators when they went to 12v they just didnt put a reg and 12v batt whole system was changed
The Red
08-26-2001 11:11:41
Afraid not. You will have to get the generator rebuilt for 12 volts. A rebuild with a new regulator should run around $125-150.
cornfused
08-26-2001 18:59:28
 Re: Re: Will 6 volt generator work on 12v in reply to The Red, 08-26-2001 11:11:41
Red, the rebuild shop down the road does not agree with you on this one. He hooked up the one off of my H and it charged 14V. He claims a regulator change will do it. I don't know for sure but he has been in the business as long as I can remember.
TomH
08-26-2001 19:33:23
 Re: Re: Re: Will 6 volt generator work on 12v in reply to cornfused, 08-26-2001 18:59:28
Someone else (I think it was Les Repair) said the same thing about changing the regulator a while ago. He explained that the generator produces a certain number of watts, you can have more volts and less amps, or vice verse depending on the regulator.
cornfused
08-26-2001 18:56:14
