Re: about to give up
- -engine
jakee
05-23-2001 14:43:20
pull the manifold one time and look down in it and see if all the heat-rizer stuff is in place and works,also see if the manifold is not ate out on the inside. i had a 706 i worked on for a long time tried every thing and found inside of manifold was ate up,then wen i put new heat rizer hardware on i had it wound wrong took it to the dealer and he set it up right,i would have never thought that the way he wound it that it would work, but it runs great now.
