Re: Has anyone ever converted a C over to a water pump??
Stan(VA).
05-14-2001 06:02:57
The water pump bolts right on in place of the lower radiator neck (2 bolts I think). Check your generator mounting bolts in case one of them is a different. I don't remember if one uses a stud instead of a bolt, etc. Also replace the upper radiator neck that bolts to the head with 3 bolts as that allows you to mount a thermostat and the sender for a temperature guage.
Stan(VA).
