Has anyone ever converted a C over to a water pump??
Kurt
05-14-2001 04:38:44
If I find a Super C with all the water pump components can I convert my 1949 C so it can use a water pump? Some people are telling me my block is different. Thank you, Kurt
David A
05-14-2001 06:09:54
 Re: Has anyone ever converted a C over to a water pump?? in reply to Kurt, 05-14-2001 04:38:44
I'm curious as to why you are doing this. My Super A was equiped new with a pump but no thermostat. Always runs too cool. Kinda wish it was just thermosyphon.
David
Kurt
05-14-2001 10:06:00
 Re: Re: Has anyone ever converted a C over to a water pump?? in reply to David A, 05-14-2001 06:09:54
Hello David. I will be removing my radiator to have it boiled out. Since I have had problems overheating while mowing, I thought I would cure it for good while the radiator was out. Are these tractors able to work hard without the water pump? Thanks, Kurt
David A
05-14-2001 10:19:08
 Re: Re: Re: Has anyone ever converted a C over to a water pump?? in reply to Kurt, 05-14-2001 10:06:00
With an overheating problem, I guess your right looking into waterpumps. But I would also add the housing that provides a thermostat. After mowing in the summer I can still hold my finger in the water - can't be more than about 120 deg. In the winter I can't even get the water hot enough to warm a cold finger. There were thousands of thermosyphon machines made and I'd kind of concluded from other postings that the system works fine under most conditions.
Stan(VA).
05-14-2001 06:02:57
The water pump bolts right on in place of the lower radiator neck (2 bolts I think). Check your generator mounting bolts in case one of them is a different. I don't remember if one uses a stud instead of a bolt, etc. Also replace the upper radiator neck that bolts to the head with 3 bolts as that allows you to mount a thermostat and the sender for a temperature guage.
Stan(VA).
