Re: Farmall M
Haas
05-04-2001 06:26:09
Don't know you consider "light garden work and mowing", but I would not think an M would be a very good choice for that kind of work. The M is a big heavy tractor and more suited to heavy work. It does not have power steering and does not steer very easy, so if you have a lot of manuevering to do, it will develop your muscles. Also if you add a 3 pt hitch, you really need to also add a 2 way spool hydraulic valve to get good control of the hitch. The Lift all hydraulic system is a one way system and when you release it, the implement will drop all the way and then you have to pick it back up to where you want it. Of course you can use stops on the hydraulic cylinders.
