Re: 1586 high side ta won’t work
The tractor vet
05-13-2019 10:43:16
Pete told you what to check and i will add in are you sure you spool valve is going all the way down and the small snap ring is touching the top of the spool valve nut . If that is all good then you are in need of a NEW T/A and there is no magic pill or devein blessing that is going to change this.
