Re: Lapping Liftall ball seats
Author |
R.Williams
03-25-2001 23:01:59
Joe, where did you find out about lapping the ball seats? About using a larger ball to lap in the seat? IHC Service Manual, IHC Liftall Service Manual?? or your idea? After lapping, maybe you should put in correct diameter ball and then gently tap it with brass punch (use new ball for final assembly) . yes, no ? Did the original ball have ring worn in it?
Joe Berendzen
03-26-2001 14:56:10
Re: Re: Lapping Liftall ball seats in reply to R.Williams, 03-25-2001 23:01:59
I got the info on lapping the check valve ball seats from the Liftall section in the IT manual. They recommend lapping the seats with the ball 1/32 larger than the valve ball. One of the two balls I removed was pitted somewhat with rust. After I posted my question, I continued to lap the valve seats and they got to where they sealed a lot better than they were, but some light still got through. They may seal 30 wt. oil just fine like I have them now. I guess I'll put it back together and see, unless someone has a better suggestion. Joe
R.Williams
03-27-2001 06:56:39
Re: Re: Re: Lapping Liftall ball seats in reply to Joe Berendzen, 03-26-2001 14:56:10
that sounds wise. if it works, that's the main thing. Joe, what was the liftall doing that made you service it? Implements slowly dropping, no lift power or what?
Joe Berendzen
03-27-2001 20:53:45
Re: Re: Re: Re: Lapping Liftall ball seats in reply to R.Williams, 03-27-2001 06:56:39
My 3 pt hitch would let the implements creep down. The brush hog was the main problem, as I would have to keep an eye on it and raise once in a while to keep it from scalping the pasture. Sometimes, it would seal and hold pretty well. When I took it apart, I found that one of the two check valve balls had more pitting than the other, and it was primarily on one half. I think that when the ball would seat on the non-pitted side, is when it would seal better. Anyway, I'm ready to put it back together when I get a gasket. I'll post my results.
Thanks, will wait for results. RW
03-30-2001 07:42:11
Re: Re: Re: Re: Re: Lapping Liftall ball seats in reply to Joe Berendzen, 03-27-2001 20:53:45
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
