Re: Frozen Stiff
Paul Shuler
02-08-2001 19:54:13
My freind you have water in your gear box. My B was the same way.You can move the shift lever but no go. Just for grins when it was about 28 one morning I took the plate off that lets you look down into the gear box. Looked fine on top but when I stuck a long screw driver down in it it a solid block of ice about 2 inchs into the oil. Wait till a warm day or put it inside and drain it and replace with some new fresh 90w. Your problem will go away
