what is it
hilario
03-22-2006 19:43:46
bought a case tractor without sheetmetal and serial number tag. don't know what model or year it is. the cylinder Head has casting number G1148 and block has G1000. The engine block also has this number stamped on it 110M00928. the tractor has three levers, one is the regular transmission lever, the other lever is to select D-H-L , but I do not know what the other lever is for. this last lever is located to the left of the operator. Please help.
Paul L
03-22-2006 20:26:48
 Re: what is it in reply to hilario, 03-22-2006 19:43:46
the hand lever I asked about and have included a link for the old thread. Paul
Joe (Wa)
03-22-2006 20:12:25
The engine is a gas 148 cid commonly found in the Case 300 series models 310 & 311. That is a very low engine serial nr, probably is a 1956 or 1957 round nose, if so the front of the bolster will be rounded.
The shifter lever marked D-H-L is a triple range gear box that gives you High-Direct drive-Low range for each gear selected on your main transmission shifter I.E. 12 speeds ahead and 3 speeds astern. If you also have a lever on your left, it is a hand clutch. The hand clutch controls ground movement by clutching in and out the transmission allowing the pto to continue running, kinda a semi-live pto setup that Case called a "constant running pto".
Joe
hilario
03-28-2006 18:02:50
 Re: what is it in reply to Joe (Wa), 03-22-2006 20:12:25
thank you for the information..now i can begin to work on getting it started and running.
