Frank, I don't know what a SP383 pulley is. Your gen pulley only needs to match the width and taper of your engine pulleys. If the O.D. of the gen pulley changes outside the span of the tensioning bracket, obviously the length of the belt will have to change. I converted my �53 VAC to alternator 8 years ago. The pulley I got was then sized for �� nominal belt width (measured across the top) and 40� taper. I used the original gen belt which was Gates 551 (now Gates TR24449 and crosses back to Case VT4886). The belt is still on there and fits the pulleys very well. I don�t know how they measure the width these days or the taper either but I think 40� nominal is pretty much automotive standard. Go to this link, lookup the belts for VAC in application. Different generator p/n�s listed will affect the length but not the width or taper. Case parts manual E61lists 3 generators and 2 belts. Gen VT3467 (autolite GAS-4169A) V-belt VT2102. Gen VT4885 (autolite GBM4823A-5) and the later replacement that includes the regulator VT3350 (autolite GHD6001-SS) apparently use the same V-belt VT4886. Go to the interchange at the link and lookup your present V-belt p/n and see if it matches the gates p/n for your application, if so use that belt to size a new pulley. Joe
