[email protected]
Richard Balder
07-29-2005 17:05:49
I have a vac -14 with a live pump mounted by the govenor. I see you said that it is 7 GPM @ 850 psi. I also see others say there are more than one size, the higher the GPM the thicker the pump. How do I determine for sure which pump I have? Does anyone know the dimensions of the standard, or high volume pump. I am designing a loader for it, and can use either flow, but need to know the gpm to select cylinders, and pivot points. Thanks for any help.
