VAC hydraulic pump GPM
Jerry W
02-13-2005 20:03:11
I know I read this awhile ago but I forgot. What is the GPM of the VAC hydraulic gear pump driven out of the magneto hole. My manual does not list it.
Thanks Jerry
Richard Balder
07-29-2005 17:05:49
 [email protected] in reply to Jerry W, 02-13-2005 20:03:11
I have a vac -14 with a live pump mounted by the govenor. I see you said that it is 7 GPM @ 850 psi. I also see others say there are more than one size, the higher the GPM the thicker the pump. How do I determine for sure which pump I have? Does anyone know the dimensions of the standard, or high volume pump. I am designing a loader for it, and can use either flow, but need to know the gpm to select cylinders, and pivot points. Thanks for any help.
Grapefarmer
02-15-2005 12:41:32
 Re: VAC hydraulic pump GPM in reply to Jerry W, 02-13-2005 20:03:11
Any chance that pump will work on a DC?
Joe (Wa)
02-13-2005 21:59:26
Manual has it at "approximate capacity 7 gpm @ 850 psi with engine 1425 rpm".
Joe
