Update
Rchard G.
07-13-2005 10:56:36
Packed the sleeve with ice and turned the puller a little more and tapped a little more. Sleeve turned loose and came up some. I am taking a Natural Light break now as it is about 90 degrees and 110 percent humidity. Hope the rest of the sleeves come out a little easier. Will try the ice first next time.
Thanks, Richard
bob stansbury
07-19-2005 19:35:01
 Re: Update in reply to Rchard G., 07-13-2005 10:56:36
Sounds like you are having better luck than I. It took me two days just to get the pistons out of an L Case which I'm told has the same motor.
By the way we had to drill the pistons out to even to get them to come loose. We broke 3 of the four sleeves in the removal of them.
This tractor has set for some 15 or so years and was flooded with diesel fuel in the cylinders for over a year before disamebly was started.
The question I have is were do we get replacement pistons and sleeves?
todd hamilton
07-13-2005 17:35:17
Since the LA would have a rather large bore you should be able to "ice-down" up to four Natural Lights while rebuilding your engine!:^)
TripleRange
07-13-2005 11:26:36
Good deal! And pretty slick trick I might add. Take 'er easy, no sense in getting heat exhaustion.
FiremanJohn
07-13-2005 14:07:54
 Re: Update in reply to TripleRange, 07-13-2005 11:26:36
If you can come up with it, you might want to try dry ice. A whole lot colder and will shrink the cylinder better.
