Pulling sleeves
Richard G.
07-13-2005 04:58:32
Trying to pull wet sleeves on a Case LA to replace the seals at the bottom. Have puller in place and very tight. Won't budge. Should I apply heat and put a hydraulic jack under the bottom. I really don't won't to damage the sleeves. Any ideas would be appreciated.
Thanks, Richard
LPGASONLY
07-13-2005 10:58:41
 Re: Pulling sleeves in reply to Richard G., 07-13-2005 04:58:32
Sounds like you might have the puller bound at the bottom. You should be able to lift the puller up and down by hand or you risk splitting the block. Is it a puck you are using ar an adjustible puller like OTC has? The puck should just catch the bottom of sleeve and not touch the block at the bottom Gary
wayne2
07-13-2005 08:51:15
I made my own puller(allthread and bar iron) had to grind to size bottom. exact opposite oof first reply. Luck
Texas Denny
07-13-2005 07:10:21
Make absolutely certain that the puller is not setting on top of the sleeve flange at the top. If it is, you'll just be trying to compress cast iron. Once you are positive the sleeve can move up, a little light taping on the puller (either rop or bottom) will often help. These usually come out pretty easy which is why I suggest checking the top for clearance.
Richard G.
07-13-2005 09:12:20
 Re: Pulling sleeves in reply to Texas Denny, 07-13-2005 07:10:21
Thanks fellas,
The puller is not on top of the sleeve flange and we have tapped the top of the puller.
Has anyone had any luck putting ice in the sleeve to shrink it?
Richard
Triple Range
07-13-2005 09:33:35
 Re: Pulling sleeves in reply to Richard G., 07-13-2005 09:12:20
Pulling sleeves can be a real mother of a job! I did so on a 630 that was all froze up by having my hand made puller pulling from top then I stuck a hydraulic jack underneath the tractor (I didn't split it) and used a long narrow piece of hardwood to jack up on the sleeve....raised the whole front end off the ground an inch. Engaged the PTO and put a big torque arm on it and turned. With a bang the sleeve popped out with the piston! No damage though, luckily. The other three came out with just the puller. I was sweatin' bullets there for a little while though.
Richard G.
07-13-2005 09:50:46
 Re: Pulling sleeves in reply to Triple Range, 07-13-2005 09:33:35
I am really trying to not break anything as this tractor has almost new M&W oversize pistons.
Thanks for the help.
Richard
Rchard G.
07-13-2005 10:56:36
 Update in reply to Richard G., 07-13-2005 09:50:46
Packed the sleeve with ice and turned the puller a little more and tapped a little more. Sleeve turned loose and came up some. I am taking a Natural Light break now as it is about 90 degrees and 110 percent humidity. Hope the rest of the sleeves come out a little easier. Will try the ice first next time.
Thanks, Richard
bob stansbury
07-19-2005 19:35:01
 Re: Update in reply to Rchard G., 07-13-2005 10:56:36
Sounds like you are having better luck than I. It took me two days just to get the pistons out of an L Case which I'm told has the same motor.
By the way we had to drill the pistons out to even to get them to come loose. We broke 3 of the four sleeves in the removal of them.
This tractor has set for some 15 or so years and was flooded with diesel fuel in the cylinders for over a year before disamebly was started.
The question I have is were do we get replacement pistons and sleeves?
todd hamilton
07-13-2005 17:35:17
Since the LA would have a rather large bore you should be able to "ice-down" up to four Natural Lights while rebuilding your engine!:^)
TripleRange
07-13-2005 11:26:36
Good deal! And pretty slick trick I might add. Take 'er easy, no sense in getting heat exhaustion.
FiremanJohn
07-13-2005 14:07:54
 Re: Update in reply to TripleRange, 07-13-2005 11:26:36
If you can come up with it, you might want to try dry ice. A whole lot colder and will shrink the cylinder better.
