Removing DC Input Shaft
Mark Sc
07-08-2005 10:05:53
Glen, I believe you have to remove the PTO gear before the shaft will come out, or you may be able to move it around and get it past the PTO gear at an angle. The PTO is powered off of the input shaft and then there is the larger gear behind it on the input shaft that drives the transmission, I think you are catching on this larger gear hitting the PTO gear.
Mark
