Removing DC Input Shaft
Glenn F.
07-07-2005 19:54:07
I need to remove the input shaft on my DC transmission in order to install the collar which the throwout bearing rides on. I do not know how this is done. I have removed the 4 main bolts which hold it but it is still not free. It comes out about an eighth of an inch and stops. Is there something else holding it. I guess I really need a shop manual. Anyone removed one? Thanks, Glenn F.
Mark Sc
07-08-2005 10:05:53
 Removing DC Input Shaft in reply to Glenn F., 07-07-2005 19:54:07
Glen, I believe you have to remove the PTO gear before the shaft will come out, or you may be able to move it around and get it past the PTO gear at an angle. The PTO is powered off of the input shaft and then there is the larger gear behind it on the input shaft that drives the transmission, I think you are catching on this larger gear hitting the PTO gear.
Mark
