Serial # Plate on Case
Scott Whalen
05-29-2005 21:43:54
Thanks for the info, I think everyone is on the right track. The sn plate on the dash is missing. I hope the eng and trans plates are some help. The rear rims are 26 inches tall.
Scott
jan hatcher
05-31-2005 11:24:48
 Re: Serial # Plate on Case in reply to Scott Whalen, 05-29-2005 21:43:54
serial # VA 5559683
on old case farm tractor
thank you
wayne woodrum
05-30-2005 19:10:22
I think it is a 470 there is no holes in the front nose for a case eagle and the side panel on the right hand front side has a place to go over the alternater.This panel is flat on 430s,if that is the factory hood and panels.
Tom (Ks)
05-30-2005 19:09:27
That might be a 470 because of the sheet metal next to the power steering pump. It is offset for a alternator, and the serial numbers for the engine and transmission are higher than my 1968 tractor. Another thing I did not see was the holes in the front of the hood for mounting the eagle.
Scott Whalen
05-30-2005 22:28:12
 Re: Serial # Plate on Case in reply to Tom (Ks), 05-30-2005 19:09:27
Great info guys. I"ve looked hundreds of pics this past weekend and never caught the offset on the right side panel. I don"t know if it the original hood or not, but the it would not fit over the alternator w/o the offset. I did not see the eagle on all the pics of 430"s that I looked at in the photo gallery. I think the serial numbers are a good indication we have a 470. Is there anything I should know before I start cleaning and repairs?
Thanks again for everyone"s info,
Scott
Scott Whalen
06-01-2005 16:56:25
 Re: Serial # Plate on Case in reply to Scott Whalen, 05-30-2005 22:28:12
Thanks Sean,
The switch has been hotwired, but at least I know what that switch is for now.
Scott
Sean in Ireland.
06-01-2005 15:09:43
The S in the gear shift pattern is for "start". There is or should be a switch on top of the gearbox and the starter solenoid is wired throgh it so that the tractor will only start when the gear-lever is in the S position. this is a safety device to prevent the tractor from being started while in gear.
