Need help identifying Case tractor
Scott Whalen
05-29-2005 09:26:28
We recently purchased a Case tractor from a neighbor. We do not the year or model. If anyone can identify it from the pics at this link we would greatly appreciate it.
Link
Thanks,
Scott
Kate in Mo.
07-21-2005 14:45:09
 Re: Need help identifying Case tractor in reply to Scott Whalen, 05-29-2005 09:26:28
Scott, from the pics it looks very much like the 430 construction king we used in our landscape business if the late 60's. I think any tractor designated LCK would have to be some type of industrial model. L=low profile CK= construction king If it is such a model, I envy you, the one we had gave us many hours of trouble free service, much better than many of the newer brands we have used since. good luck with it kate
Scott Whalen
07-22-2005 18:50:20
 Re: Need help identifying Case tractor in reply to Kate in Mo., 07-21-2005 14:45:09
Thanks for the reply Kate. I"m sure there"s many more years of service out of her. I"ll post some pics after we get her painted. Hopefully that will be before the end of the summer.
Thanks again,
Scott
Old Rusty
05-29-2005 19:27:21
My money would go to a 430LCG (low center of gravity)
Leroy
05-29-2005 17:45:42
It is not a cultivation tractor because the front axle is too low and the hood looks too long for an agricultural version and from the tach it shows to have a 4 speed transmission that was not normal in an ag tractor
Les...fortunate
05-29-2005 15:35:07
Here"s your link so that people can just click on it. Nice looking tractor. I don"t know anything about those new tractors. That one"s way too new for my tastes.
John H-WI
05-29-2005 14:45:58
Not sure where you got the number but the serial number plate should be on the dash. Couldn't find any numbers such as you listed but the 148 CI was a common gas engine used in the B series era. Looks like from you pictures its an industrial version of the B version. Someone may be able to pin it down closer from the number you gave, possibly the transmission number?
Ed in Maine
05-29-2005 14:43:38
Maybe a mid sixties 430? The serial number doesn't make sense though, nothing is listed for a model that has a SN starting with a 2. Nice looking tractor though. Could be a utility if rims are 24", farm tractor came with 28" rims (which is what it looks like). Ed
Scott Whalen
05-29-2005 21:43:54
 Serial # Plate on Case in reply to Ed in Maine, 05-29-2005 14:43:38
Thanks for the info, I think everyone is on the right track. The sn plate on the dash is missing. I hope the eng and trans plates are some help. The rear rims are 26 inches tall.
Scott
jan hatcher
05-31-2005 11:24:48
 Re: Serial # Plate on Case in reply to Scott Whalen, 05-29-2005 21:43:54
serial # VA 5559683
on old case farm tractor
thank you
wayne woodrum
05-30-2005 19:10:22
I think it is a 470 there is no holes in the front nose for a case eagle and the side panel on the right hand front side has a place to go over the alternater.This panel is flat on 430s,if that is the factory hood and panels.
Tom (Ks)
05-30-2005 19:09:27
That might be a 470 because of the sheet metal next to the power steering pump. It is offset for a alternator, and the serial numbers for the engine and transmission are higher than my 1968 tractor. Another thing I did not see was the holes in the front of the hood for mounting the eagle.
Scott Whalen
05-30-2005 22:28:12
 Re: Serial # Plate on Case in reply to Tom (Ks), 05-30-2005 19:09:27
Great info guys. I"ve looked hundreds of pics this past weekend and never caught the offset on the right side panel. I don"t know if it the original hood or not, but the it would not fit over the alternator w/o the offset. I did not see the eagle on all the pics of 430"s that I looked at in the photo gallery. I think the serial numbers are a good indication we have a 470. Is there anything I should know before I start cleaning and repairs?
Thanks again for everyone"s info,
Scott
Scott Whalen
06-01-2005 16:56:25
 Re: Serial # Plate on Case in reply to Scott Whalen, 05-30-2005 22:28:12
Thanks Sean,
The switch has been hotwired, but at least I know what that switch is for now.
Scott
Sean in Ireland.
06-01-2005 15:09:43
The S in the gear shift pattern is for "start". There is or should be a switch on top of the gearbox and the starter solenoid is wired throgh it so that the tractor will only start when the gear-lever is in the S position. this is a safety device to prevent the tractor from being started while in gear.
