Case 430, is it a good tractor ?
Robert Paris
03-06-2005 15:55:40
It is a Case 430. Don't have much info, 40 HP, 2 WD, 1963,gaz engine,triple-range 12 speed, good rubbers. Will have to go and see. Is powersteering standard on 430's ?
Dennis/Ohio
03-10-2005 01:48:41
 Re: Case 430, is it a good tractor ? in reply to Robert Paris, 03-06-2005 15:55:40
530 is 40HP, I think 430 is closer to 36HP.
530 is 159 cu. in. & 430 is 148 cu. in. gas engines. If diesel they both would be 188 cu. in. but HP would be adjusted same as above.
Patrick (Mich.)
03-07-2005 21:22:42
 430 specs. in reply to Robert Paris, 03-06-2005 15:55:40
Robert, power steering was not standard equipment on the 430 ag series tractors. I believe that it is more common to find that feature on the later production machines, but early ones may or may not have it. The good news is that if you find a really good tractor at a good price but w/o power steering, you can always switch it out from a junker if you need to.
