That's what I was looking for
Augie
03-04-2005 10:56:51
Wanted to make sure it would fit before I started throwing money around.
Our club has the "can't use it if it's not in the parts book" rule for external parts in farm stock, so the 148 crankcase is out.
No Name VAC
03-04-2005 20:32:13
 Re: That's what I was looking for in reply to Augie, 03-04-2005 10:56:51
The 148 crank will not fit in the VAC block. It is longer due to a thicker rear throw. I was going to replace the crank in ours but ran into this problem. Decided to replace the block to after that. Good luck.
Augie
03-05-2005 06:42:09
 Re: That's what I was looking for in reply to No Name VAC, 03-04-2005 20:32:13
I've been told that the 148 crank will go, but takes some machine work to do it. I've got plenty of 124 parts so I'll use what I have.
.5" added to the throws and a .125" offset grind adds up to 5".
Looks like it's time to bring a crankcase into the shop and start measuring...
