Poke and stroke question
Augie
03-03-2005 12:37:33
What's the most cid that you've heard of being built in a VAC 124 crankcase? Rules preclude use of a larger crankcase.
Is there room to go 3.75x5? More? Less?
No Name VAC
03-04-2005 07:45:33
 Re: Poke and stroke question in reply to Augie, 03-03-2005 12:37:33
3.75" will work for bore. 4.75" is about the max with stock rods. 5" will require custom rods due to cam location. If you can get by with a 148 block and crank it will be easier due to having a longer stroke to begin with. It will bolt in with out modifications, but is about 1/4" longer. Rear oilpan rail will have to be ground to clear flywheel.
Augie
03-04-2005 10:56:51
 That's what I was looking for in reply to No Name VAC, 03-04-2005 07:45:33
Wanted to make sure it would fit before I started throwing money around.
Our club has the "can't use it if it's not in the parts book" rule for external parts in farm stock, so the 148 crankcase is out.
No Name VAC
03-04-2005 20:32:13
 Re: That's what I was looking for in reply to Augie, 03-04-2005 10:56:51
The 148 crank will not fit in the VAC block. It is longer due to a thicker rear throw. I was going to replace the crank in ours but ran into this problem. Decided to replace the block to after that. Good luck.
Augie
03-05-2005 06:42:09
 Re: That's what I was looking for in reply to No Name VAC, 03-04-2005 20:32:13
I've been told that the 148 crank will go, but takes some machine work to do it. I've got plenty of 124 parts so I'll use what I have.
.5" added to the throws and a .125" offset grind adds up to 5".
Looks like it's time to bring a crankcase into the shop and start measuring...
