Is that a freeman loader,,,ctx
Gregg in ohio
03-02-2005 16:43:36
i also have a 52 VAI and needing a loader...where did the blue paint come from..very good tractors wish mine had a live pto..gregg
laipuller
03-02-2005 20:37:08
 Re: Is that a freeman loader,,,ctx in reply to Gregg in ohio, 03-02-2005 16:43:36
to kill 2 birds with one stone, wishe they did make live pto, but they didn't.. when you go to replace the brake seals, take your shim packs apart clean each one and put a light coat of gasket shellaq between the shims. this helps out alot tooo.
Puttz
03-02-2005 17:57:49
I have no idea weather the loader was a specific brand or a massive undertaking of folk art.
I think the previous owner liked Fords. So it's two shades of Ford engine paint? It's got an Autolite alternator.
Arthur
03-03-2005 03:41:40
 Re: Is that a freeman loader,,,ctx in reply to Puttz, 03-02-2005 17:57:49
I have a "47" VAI with the same loader. It should say "Profit" on the top support member. This is a loader Case offered w/ the VAI when new. The hyd oil res. is mounted to the loader frame, so that means that there should be 90 wt gear lube in the torque tube. The manuals are still available from Rich, at Case.(can't remember his last name for the life of me....somebody help me out here)I would sejust that you buy a set....Your going to need them to find out how to change all the seals on that.Good luck w/ your new tractor
Ryan - WI
03-03-2005 18:14:33
 Re: Is that a freeman loader,,,ctx in reply to Arthur, 03-03-2005 03:41:40
I believe his last name is Tworek
Puttz
03-03-2005 06:13:56
Just looking at it, the loader frame is in the way of the brake covers.
Oh what fun.
