VAi and the oils , they run out
Puttz
03-02-2005 16:31:07
third party image
I checked out my 47 VAi for lube the other day and about ten gallons of water came out when I pulled the plug.
I ran down to Walmart and bought 4 gallons of thier thickest stuff 90-140. I found that just the forward section, that might include the steering box took a gallon right away.
Then I moved on to the big square plug that has the dipstick on it. It might have been 8 or more gallons (alltogether), when it started showing well on the stick.
Now I see it drooling quite well from the brake housing lower vent holes.
I have a question.
Will it stop flowing and still have a safe amount aboard, or are there seals at the brake shafts that need attention?
Oh and incidently I made up a shifter boot, to keep the water out, thingie. I think that's where the water came in.
Joe (Wa)
03-02-2005 17:56:07
 Re: VAi and the oils , they run out in reply to Puttz, 03-02-2005 16:31:07
1947 if you aren't using the torque tube as a hydraulic reservoir, leave the heavy oil in there. Less likely to leak into transmission via the drive shaft seal and suitable to lube the the bearing & belt pulley drive gear. Original oil there for you tractor was SAE 90.
Brake shaft seals should be replaced, You still won't have good brakes cuz this is a typical NO BRAKES CASE tractor.
Joe
Paul f
03-02-2005 17:14:05
There are two separate reservoirs...the torque tube (runs from engine to the transmission. That takes 2 gals of hydraulic fluid or 10w..filler is opn left side of tube. Transmission take 90 w or 85-140 your call and takes 7 gals ( dip stick on filler cap). Yes there are seals on the brake shafts and they will leak. Not that hard to replace.
Gregg in ohio
03-02-2005 16:43:36
 Is that a freeman loader,,,ctx in reply to Puttz, 03-02-2005 16:31:07
i also have a 52 VAI and needing a loader...where did the blue paint come from..very good tractors wish mine had a live pto..gregg
laipuller
03-02-2005 20:37:08
 Re: Is that a freeman loader,,,ctx in reply to Gregg in ohio, 03-02-2005 16:43:36
to kill 2 birds with one stone, wishe they did make live pto, but they didn't.. when you go to replace the brake seals, take your shim packs apart clean each one and put a light coat of gasket shellaq between the shims. this helps out alot tooo.
Puttz
03-02-2005 17:57:49
I have no idea weather the loader was a specific brand or a massive undertaking of folk art.
I think the previous owner liked Fords. So it's two shades of Ford engine paint? It's got an Autolite alternator.
Arthur
03-03-2005 03:41:40
 Re: Is that a freeman loader,,,ctx in reply to Puttz, 03-02-2005 17:57:49
I have a "47" VAI with the same loader. It should say "Profit" on the top support member. This is a loader Case offered w/ the VAI when new. The hyd oil res. is mounted to the loader frame, so that means that there should be 90 wt gear lube in the torque tube. The manuals are still available from Rich, at Case.(can't remember his last name for the life of me....somebody help me out here)I would sejust that you buy a set....Your going to need them to find out how to change all the seals on that.Good luck w/ your new tractor
Ryan - WI
03-03-2005 18:14:33
 Re: Is that a freeman loader,,,ctx in reply to Arthur, 03-03-2005 03:41:40
I believe his last name is Tworek
Puttz
03-03-2005 06:13:56
Just looking at it, the loader frame is in the way of the brake covers.
Oh what fun.
