Another thought...
Old Eb
02-13-2005 15:30:35
Since it sounds like you are going to need another rim anyway, you could put a replacement on and remove the keystock from the axle where it "engages" the axle/hub assembly, loosen the hub bolts a bit and let the hub rotate around the axle long enough to roll onto a trailer. Once on the trailer you could jack up one side at a time, rotate the wheel & replace the keystock so as to help secure the unit. It works - have done it that way myself.
third party image
rgorange
02-13-2005 16:30:26
 Re: Another thought... in reply to Old Eb, 02-13-2005 15:30:35
Thanks Eb.
I'll keep that in mind. Although a new rim is a long way off. I may be able to temporarily use the old one if I do it that way. Thanks again.
