stuck engine
Patrick (Mich.
10-19-2004 10:06:16
The engine was stuck from sitting for 10+ years, and some water had gone down the exhaust manifold, rusting #2 and #3 cylinders. It was seized to the point that a 3 foot prybar working against the flywheel ring gear wouldn't budge it. I freed by soaking the cylinders for two days in automatic transmission fluid. It broke free right away after the soaking, by just working the engine back and forth a little more each direction with the prybar. After freeing the pistons, two exhaust valves were sticking, but a bit more effort and some WD-40 also loosened them.
INCase
10-19-2004 10:37:44
 Re: stuck engine in reply to Patrick (Mich.), 10-19-2004 10:06:16
wow.. been soaking my, VERY similar sounding 730 for a couple years now (ok I don't get to mess with it very often)..haven't tried the pry bar yet. just rocking the wheels.... what did you do with the internal engine rust? WHere are you in Michigan? I work in SE MI and live in NCentral Indiana. did you check on mufflers yet??
Patrick (Mich.)
10-19-2004 21:37:50
 Re: stuck engine in reply to INCase, 10-19-2004 10:37:44
Well, I didn't really find much internal engine rust other than what had occurred in the cylinders. The valve train was in very good condition when I pulled the valve covers off. There was a bit of water that drained out of the crankcase when I first removed the plug, but not enough to where the crank journals would have been exposed to it. I did put about a gallon of diesel fuel into the oil pan and let it soak for a day to help flush out any contamination that had settled there. Any remaining rust was worn off the cylinders in the first minutes of running it. The tractor only smoked for the first little bit, and now the exhaust has no trace of oil burning. I checked all over the internet today, but no answers came up about the muffler. I think that the next step is to ask the dealer. I live in the center of Michigan, near Lansing.
