Shawn, it is a model 2390 Case tractor.
ZSmith
09-06-2004 16:30:01
I went over there today, and it says 2390 on the side in black numbers. Like I said, I put it in neutral and coasted down the hill. Then I tried to shift it into 4th (I guess its actually high range?) twice, but it didn't want to go in, so I stopped and pushed the clutch down and it shifted into gear, but when I lifted the clutch up it wouldn't go. It only goes in 1st 2nd and 3rd gear. By the way, you can't push the clutch in if its in a higher gear than 1st or it will break something on the clutch. That's why I put it into neutral, but now I know that you're not supposed to coast with it in neutral. I hope that it's something minor like a broke or loose cable, but it's probably not. Maybe I won't break another one. Thanks again.
