WHY DID THE ROAD GEAR QUIT WORKING??
ZSmith
09-04-2004 14:09:11
I was driving a dual wheel Case tractor on the highway and I put it in neutral to coast down the hill. I tried to put it back into road gear after slowing and reaching the botton of the hill, but it wouldn't go into high gear. Then I stopped, pushed the clutch in, and shifted it into high, but when I let off the clutch it didn't move. So I put it in 3rd gear and drove it the rest of the way. What do you think happened to 4th gear?
Shane
09-04-2004 15:04:42
 Re: WHY DID THE ROAD GEAR QUIT WORKING?? in reply to ZSmith, 09-04-2004 14:09:11
First of all what model are we talking here. Second, bad idea to put it in neutral.... just let it roll in gear and that way you don't get out of control.
ZSmith
09-04-2004 16:35:00
 Re: WHY DID THE ROAD GEAR QUIT WORKING?? in reply to Shane, 09-04-2004 15:04:42
I don't know what the model is, but it has dual rear wheels and about 135-150HP. I think its a turbo diesel and it has a cab with an A/C. The reason that I put it in neutral is because you can't push the clutch down when it is in a high gear. Thanks for the reply. Oh I think it is a 1980's model.
Shane
09-06-2004 06:17:51
 Re: WHY DID THE ROAD GEAR QUIT WORKING?? in reply to ZSmith, 09-04-2004 16:35:00
I am guessing it is a powershift model, either a 70 or 90 series. Why put it in neutral? Why can't you push in the clutch with it in gear? Sounds like there are some serious problems here.
ZSmith
09-06-2004 16:30:01
 Shawn, it is a model 2390 Case tractor. in reply to Shane, 09-06-2004 06:17:51
I went over there today, and it says 2390 on the side in black numbers. Like I said, I put it in neutral and coasted down the hill. Then I tried to shift it into 4th (I guess its actually high range?) twice, but it didn't want to go in, so I stopped and pushed the clutch down and it shifted into gear, but when I lifted the clutch up it wouldn't go. It only goes in 1st 2nd and 3rd gear. By the way, you can't push the clutch in if its in a higher gear than 1st or it will break something on the clutch. That's why I put it into neutral, but now I know that you're not supposed to coast with it in neutral. I hope that it's something minor like a broke or loose cable, but it's probably not. Maybe I won't break another one. Thanks again.
