Re: Hmmm....410 gear shifter puzzling!
JHH
07-27-2004 19:41:51
TOG, Do a search on "400 shift pattern" There are a couple of posts under 400 super deisel that explain how it should work
Doc Larry
07-27-2004 20:10:27
 Re: Re: Hmmm....410 gear shifter puzzling! in reply to JHH, 07-27-2004 19:41:51
third party image
Here's the 401 owner's manual shift pattern. I find the upper left pattern most understandable. As a former truck driver, I thought I'd seen all but this was a new one for me. You can only go from High to Low range and back in the position shown, you will do this accidentally quite often until you get the hang of it. One other thing to keep in mind is that the actual position of the shift stick overlaps quite a bit across the high to low range gear positions.
Have fun!
Larry
