Hmmm....410 gear shifter puzzling!
ThatOtherGuy
07-27-2004 19:26:11
Well I got my Case running and moving. There's only one problem...the only gears I know are what I think 1st, 2nd, and reverse. Can someone tell me how that shifter works? Im not sure but I think there is a hi and lo section on the shifter? I think its like 8 speed in total or something.
Any help will be appriciated.
Thanks,
ThatOtherGuy
ThatOtherGuy
07-27-2004 20:38:33
 Re: Hmmm....410 gear shifter puzzling! in reply to ThatOtherGuy, 07-27-2004 19:26:11
Thanks, guys.
Tommorow I will play with it more and see if I can get used to it.
Man, it seems like Case went with some odd and unique things when compared to the IH Farmalls! Im glad to have a good size Case now to go with my IHs!
ThatOtherGuy
Pat T
07-28-2004 03:31:27
 Re: Re: Hmmm....410 gear shifter puzzling! in reply to ThatOtherGuy, 07-27-2004 20:38:33
I have to give the strangest shift pattern award to the Johnny Poppers. The 400 makes sense compared to those things.
JHH
07-27-2004 19:41:51
TOG, Do a search on "400 shift pattern" There are a couple of posts under 400 super deisel that explain how it should work
Doc Larry
07-27-2004 20:10:27
 Re: Re: Hmmm....410 gear shifter puzzling! in reply to JHH, 07-27-2004 19:41:51
third party image
Here's the 401 owner's manual shift pattern. I find the upper left pattern most understandable. As a former truck driver, I thought I'd seen all but this was a new one for me. You can only go from High to Low range and back in the position shown, you will do this accidentally quite often until you get the hang of it. One other thing to keep in mind is that the actual position of the shift stick overlaps quite a bit across the high to low range gear positions.
Have fun!
Larry
