611B Oil Filter Mystery
Kirk In Oregon
05-02-2004 22:04:48
OK, some of you may remember I hauled home a very tired 611B last fall. Embarrassed to say I never got around to changing the oil until today. Bought a new filter at NAPA, dropped the black liquid out the bottom, unscrewed the old filter and found A MYSTERY!!!!! Somebody had crammed a wooden dowel into the hole in the center of the filter base. I assume this is where the clean oil leaves? The little stick is about 4 inches long with a nice point on top and a hand whittled base to perfectly fit the hole like a cork. Why would somebody do this???? Worst part is, NAPA sold me the wrong filter - has female thread base not male - so I had to put it back. And that filter was all rusty and nasty inside so I left the stick in until I can get a clean filter. Any ideas on what in the #&%#$ is going on here would be most welcome! Kirk.
p.s. this poor thing leaks a lot and smokes some. But it actually works good and was pretty cheap for a loader tractor. I have no regrets YET!
Russ
05-03-2004 16:41:26
 Re: 611B Oil Filter Mystery in reply to Kirk In Oregon, 05-02-2004 22:04:48
TRY THIS SITE; ITS PRETTY TECHNICAL BUT MAY HELP YOU UNDERSTAND HOW A BYPASS OIL FILTER WORKS.
Link
PAUL FROM MICHIGAN SEEMS TO HAVE A GOOD HANDLE ON THIS SUBJECT. YOU MAY BE ABLE TO POST YOUR QUESTION DIRECTLY TO HIM.
Joe (Wa)
05-02-2004 22:44:40
The wooden dowel was put in there by the manufacturer to keep the filter media separated. When you install the filter, remove the dowel and slide the filter down over the oil inlet stem tube and screw it up tight.
The correct filter is Napa 1104. It has an external rolled thread near the same as a mason jar
Joe (Wa)
05-02-2004 23:19:46
 Re: Re: 611B Oil Filter Mystery in reply to Joe (Wa), 05-02-2004 22:44:40
Well I guess I confused the issue by not reading you post carefully.
The dowel is still in there because the last person did not remove it before installing the filter. Yes it was put in there by the manufacturer for the reason stated above.
Your post indicates the oil inlet stem tube is missing from the filter housing. It is near 1/4" dia x 3-3/4 L. Next time you pull the filter off, look up in there next to the dowel, it may be there. Odds are it is in an old filter that went to the dump years ago.
If you need measurements to press in a new one or further info, post.
Joe
Kirk
05-03-2004 07:03:00
 Re: Re: Re: 611B Oil Filter Mystery in reply to Joe (Wa), 05-02-2004 23:19:46
Thanks Joe! This all makes sense now. Yes, the tube is gone. Will try to make a replacement. I would like to get the filter working again. KL
Joe (Wa)
05-03-2004 08:08:00
 Re: Re: Re: Re: 611B Oil Filter Mystery in reply to Kirk, 05-03-2004 07:03:00
The 611b has the same oil filter housing as the Vac.
This thread may save you some time. 0.081" = #46 drill
0.093" = #42 "
Holes are used direct the oil and saturate the top of the filter media and size is not critical.
Joe
