Re: ‘62 Case 310 weak spark
rustred
02-15-2020 15:12:47
neg. to chassis is negative ground. do the simple thing... hook a wire from battery pos. to pos. terminal on coil. the negative lead should be going to distributor for a 12 volt system. if all is in order it will start. throw that tester away, remove plugs and check the actual spark at the plugs. you will hear it snap and it will be blue. if it starts you can do the rest later.
ceige
02-22-2020 12:00:30
 Re: ‘62 Case 310 weak spark in reply to rustred, 02-15-2020 15:12:47
Finally got a chance to try everyone’s suggestions. I first pulled the #4 plug and it is clearly sparking to ground. I have not tried hot wiring the coil yet. Is that necessary since I know I am getting spark at the plug?
