580 engines
Roger (Mi)
04-21-2008 01:36:47
The 580 gasoline engine from the factory is 159 CID, and parts are available from dealers or after-market. The 159 gasoline engine (43 HP rating) is also found in the 530 agricultural tractors. There was a 188 gasoline engine, but it was only available in the 630 agricultural tractor. All diesels for the 580 were 188 CID.
C.
04-21-2008 15:55:38
 Another question. in reply to Roger (Mi), 04-21-2008 01:36:47
Hi
If the 580 came w/ 159 gas & 188 D, will the 188D replace the 159 ie same bolt patterns bell housing etc. Can"t find any 530/40/70 tractors at all but I do know where there"s a 188D engine for sale.
Thanks
C.
tom stanley
04-22-2008 06:01:02
 Re: Another question. in reply to C., 04-21-2008 15:55:38
you need to make sure where the oil filter mounts early 188 were standing upright this makes the mounting of the power steering pump with tank not work and there was a 188 gas and a 201 gas unit also
Roger (Mi)
04-21-2008 21:23:13
 Yes, gas and diesel are interchangeable, but... in reply to C., 04-21-2008 15:55:38
The diesel is slightly longer than the gasoline engine. You would need to work around some problems i.e. hood, throttle linkage, fuel lines, diesel return line to tank, steering shaft, etc.
