My bad
Roger (Mi)
03-16-2008 00:25:38
Should have look closely at your pictures. Obviously, you're not using the 3 point lift (no lift arms attached). Whenever there is massive transfer of hydraulic oil into the transmission, it's the 3 point lift piston seal. As mentioned by others (mEl), it's likely the seal between the torque tube and transmission. Could also be the seal under the rockshaft cover that seals the input shaft to the PTO shaft. However, those two shafts turn in unison except when using the hand clutch. The wear on that seal should be miminal. However, if the seal carrier came out of the transmission input shaft (it's pressed in), the transfer of hydraulic oil into the transmission would be substantial. As mentioned before, the only other way for transfer to occur is the seal between the torque tube (transmission input shaft) and transmission. The easiest way to check that seal is to pull the transmission gear shift cover. Make sure the hydraulic oil is at the proper level in the torque tube and look for seepage around the transmission shaft into the transmission. If it's bad, you'll need to split the tractor to replace it.
