MORE INFO
Larry59
03-05-2008 17:01:12
Ok.. tried ever gear... d, Low , and a high. Would not turn the motor over in two. But would turn motor over with starter?
Seems like I got only an inch of clutch at the top end????? Will pull tractor after it started but sure would not turn motor over in pull.
J heitkemper
03-07-2008 17:30:01
 Re: MORE INFO in reply to Larry59, 03-05-2008 17:01:12
Larry , FROM EARLIER POSTS COUPLE WEEKS OR SO BACK ,If this tractor is CASE-O-matic , You could pull it forever and never spin the motor , Only way to start is with Starter Motor ,,,,, ,
mEl
03-05-2008 18:35:31
let some free travel into the pedal, lengthen the rod that goes into the bell kousing and see what happens, read my other post again
Larry59
03-07-2008 20:41:27
 Here is what I found out. in reply to mEl, 03-05-2008 18:35:31
My tranny is a triple range making it 12 forward. Reading up , I found the case o matic came out in the 400B tractors of 58 and not the 300B. My tractor is a 300B type. So must be the clutch and have been able to get out and work on it. To dang cold and I don't have nothing but a canopy top over it. ... Thanks for the info
