How about a DO (tractor fuel)
caseAlot
03-04-2008 13:31:17
Would a DO that ran on tractor fuel be a better fit?
To answer the other Qs...Haven't started making fuel, just noodling the idea. The ability to grow your own fuel is interesting. I'm in Florida and have excess fruit year round...also could grow sugar cane if needed...Wanted to do it more for the knowledge/novelty rather than running a tractor all day every day...
shawnspeed3
03-04-2008 16:21:58
 Re: How about a DO (tractor fuel) in reply to caseAlot, 03-04-2008 13:31:17
the key to it all is tuning &tinkering. The higer the compression ratio the more efficent it will be . Also what type of still do you plan on using????pot stills don't usually give a pure enough product to give good results for motorfuel they reccomend a fractional distiller that will produce 90% or better 180 proof as the remaining 10 % is usually water and more water means richer fuel mixture and more fuel. I would reccomend doinga search for the David brown Alcohol fuel handbook/website and ask some honestquestions. Also , you mite have to change oil a little more often , as if any fuel gets in the oil due to blow-by it turns the oil milky, and it will attract moisture.....Shawn
