No need to bleed injectors.
Roger (Mi)
02-28-2008 03:41:45
The Roosa-Master is a self bleeding pump. Once there is fuel to the pump, tighten all the lines and crank it up. Generally, 430 diesels had nearly 40 horsepower from the factory. The 630 settings will give it 52 horsepower. The timing will need to be changed from 4 degrees BTDC to 8 degrees BTDC. That's it.
