Case 430
R F W
02-27-2008 11:54:26
I have a Case 430 diesel [1965] I am going to take the fuel injector pump[Roosa Master] off and have it tuned up to a 630 spec.to give me more HP I know I need to line up the marks in the little window on the pump ,When i reinstal the pump how do I get the diesel fuel through the injector pump to restart the motor any help or suggestions would be appreciated.Have a safe great day Thank you Barney
mEl
02-28-2008 04:32:37
 Re: Case 430 in reply to R F W, 02-27-2008 11:54:26
I have a pump ready to go on my 530 (188)diesel that is set to 207 specs and also has the 0 degree start mod done to it, this was done on the 580C 207's to aid cold start, getting the fuel in when the heat is greatest in the combustion chamber.
Paul in On
02-27-2008 20:00:32
That something easy to do? I may do that with my 430 then . . . what"s the disadvantages if any? burn more fuel I suppose . . .
mEl
02-27-2008 16:32:23
Have your diesel shop check the calibration figures on the Case 450 crawler loader pump, use whichever is higher, the 630 or the crawler. when we were heavy into that series engine and stocked rebuilds we always used the 450 specs for all. No one complained about some extra power.
Tom (Ks)
02-27-2008 19:53:06
 Re: Case 430 in reply to mEl, 02-27-2008 16:32:23
Did you take the rpm's up to 2100 or 2250rpm's???
srw
02-27-2008 15:55:14
There will be a bleed screw on the top cover of the pump. You can loosen that screw and either gravity fuel through the pump or pump it through if there is a primer pump on the tractor. After good fuel through the bleed screw tighten it and loosen the fuel lines at the injectors and crank the tractor. When good fuel at them start closing the lines. not hard just make sure the pump has good fuel from the bleed screw.
Roger (Mi)
02-28-2008 03:41:45
 No need to bleed injectors. in reply to srw, 02-27-2008 15:55:14
The Roosa-Master is a self bleeding pump. Once there is fuel to the pump, tighten all the lines and crank it up. Generally, 430 diesels had nearly 40 horsepower from the factory. The 630 settings will give it 52 horsepower. The timing will need to be changed from 4 degrees BTDC to 8 degrees BTDC. That's it.
