The bottom hydraulic valve is totally used
Roger (Mi)
01-11-2008 02:01:57
Yes, the 3 point lift is a single acting cylinder. However, it uses hydraulic pressure on the other side of the lower valve spool to open the hydraulic interlock. That allows hydraulic oil from the 3 point cylinder to dump back to sump. In other words, both sides of the lower valve are used equally. Your least expensive (assuming the remote valve is seldom used) route for correcting the problem is to try swapping the two valves. Make sure to tighten the valve body bolts from the outside in and no more than 15 lbs. torque. Otherwise, the valve spools will likely bind. Good luck, Roger
