Need to replace the lower hydraulic valve body
Roger (Mi)
01-10-2008 03:47:30
The (three point) lower hydraulic valve body has too much wear. The remote hydraulic valve body is stacked on top of the 3 point valve body. Whenever the remote hydraulic valve body on top is activated, an equal pressure is present in the center of the lower valve body. If there is any wear in the lower (three point) spool and valve body, pressure will seep by the valve spool and will cause the three point to go up. If the remote hydraulic valve body is seldom used (less wear), you could swap valve bodies. (top to bottom and bottom to top) Just make sure the hydraulic interlocks are in their original locations. If both valve bodies are often used, you'll need to replace the lower (three point) valve body to correct your problem.
Joe (Wa)
01-10-2008 11:41:56
 Re: Need to replace the lower hydraulic valve body in reply to Roger (Mi), 01-10-2008 03:47:30
Thanks Roger, that is better description.
Assuming the lower control valve spool is centered than it has to be leaking bye to raise the hitch.
I've worked on these valves & interlocks on my tractors and there is quite a lot of teardown to swapping valves & relocating the interlocks.
Some questions:
1. The lower control valve interlock is setup SA so we are presently using only 1/2 the control valve spool for both raise and lower of the hitch?
2. Do you think it would be worth the effort to swap the hitch line and pipe plug on the interlock to use the other end of the spool before getting into a valve swap?
Joe
Roger (Mi)
01-11-2008 02:01:57
 The bottom hydraulic valve is totally used in reply to Joe (Wa), 01-10-2008 11:41:56
Yes, the 3 point lift is a single acting cylinder. However, it uses hydraulic pressure on the other side of the lower valve spool to open the hydraulic interlock. That allows hydraulic oil from the 3 point cylinder to dump back to sump. In other words, both sides of the lower valve are used equally. Your least expensive (assuming the remote valve is seldom used) route for correcting the problem is to try swapping the two valves. Make sure to tighten the valve body bolts from the outside in and no more than 15 lbs. torque. Otherwise, the valve spools will likely bind. Good luck, Roger
