I got it started - more pics
Joe Stewart
11-30-2007 03:36:34
OK, I had another gentleman use another tractor to pull me around the pasture with the 930 in gear. Ether just caused it to pop a couple of times, so I guessed fuel was not getting to injectors. Cracked the lines at the injectors and pulled => fuel came out in short order. Took about ten minutes of pulling but she finally started up. Puts out A LOT of smoke, but seems to run ok otherwise. Number six injector is not injecting - the rest work fine. The three point lift works; forgot to check if PTO worked. There appears to be tons of blow-by. I parked it in the back of the barn and hopefully will take off the heads in the next couple of month. Thanks for all input.
third party image
third party image
third party image
third party image
J Heitkemper
11-30-2007 17:20:23
 Re: I got it started - more pics in reply to Joe Stewart, 11-30-2007 03:36:34
Good Work Joe !!...if the goal is to have a puller and hard worker tractor ,, And You like tinkering and have the money to spend to fix it and do her up right , HAVE AT IT ! However , if you are trying to make ends meet and are not eager to overhaul this beast of a girl ,, You could try some LUCAS oil additive in the engine oil and LUCAS fuel conditioner in the fuel ,and tool around a while to see if she improves , If the tractor has been setting a while , All sorts of smoke will belch forth ,especially from old Fuel ,, Best Wishes ,, jim
