Hydraulic oil in the rear end?
Roger (Mi)
09-21-2007 05:19:37
One could use hydraulic oil (instead of the recommended 90W gear lube) in the rear end if you're NOT using the tractor for heavy tillage. Using hydraulic oil in the rear end for heavy work will cause premature wear and eventual failure of the pinion side gears.
