csae 430 oil
Rick Lawson
09-20-2007 02:13:56
I have a 69 case 430 gas tractor. The trans. uses 90w and differ. use hyd. Can I drain it all out and use trans/hyd fluid instead.
bradley martin
09-20-2007 07:37:02
 Re: csae 430 oil in reply to Rick Lawson, 09-20-2007 02:13:56
You have the transmission & rear end oils reversed but ,yes, you can use hydraulic oil in both.
Roger (Mi)
09-21-2007 05:19:37
 Hydraulic oil in the rear end? in reply to bradley martin, 09-20-2007 07:37:02
One could use hydraulic oil (instead of the recommended 90W gear lube) in the rear end if you're NOT using the tractor for heavy tillage. Using hydraulic oil in the rear end for heavy work will cause premature wear and eventual failure of the pinion side gears.
