Oil slinger driven by third/fourth gear
Roger (Mi)
09-12-2007 06:00:26
The purpose of the oil slinger (which is driven by the third/fourth gear) is to throw oil into the upper oil galleries when the tractor is in neutral. That lubricates the input shaft bearings which would otherwise run dry. The washer that holds the slinger in place is next to the front spacer on the pinion shaft. The dimple on the washer is likely keyed into the third gear on the pinion shaft.
