No need to remove the axle housing.
Roger (Mi)
09-08-2007 05:20:16
When the bull gear nut is removed, the axle is only being held in place by the pressure fit of the inner axle bearing. Remove the wheel, then pry between the two axles. The axle without the nut will move out, but will force the outer axle seal out with it. No problem! When done with repairs, the axle seal can be pushed back into place.
