This trick may work
Roger (Mi)
09-04-2007 17:18:02
The following trick works well on Ford 9N, 3N, and 8N tractors to free up a stuck clutch. Loosen the bellhousing bolts so there is a 1/2 inch gap at the bottom between the transmission and engine. Start the engine, and push down on the clutch pedal. Immediately, the clutch disk will break free from the flywheel! Tighten the bellhousing bolts, and you're good to go.
Walt Davies
09-04-2007 18:30:33
 Re: This trick may work in reply to Roger (Mi), 09-04-2007 17:18:02
I not real sure but isn't the Case SC a wet clutch that wouldn't work to well if so.
Walt
Roger (Mi)
09-05-2007 05:57:42
 You're right about the SC in reply to Walt Davies, 09-04-2007 18:30:33
Yes, the SC has a wet clutch. If the bellhousing bolts were loosened on a SC, what an oily mess! At least there are a couple of side plates on the SC to get to the clutch. The 310B has none.
