stuck clutch plate
nuley
09-04-2007 14:47:18
Case 310B - single plate clutch
Clutch plate is rusted to flywheel. Tried turning it over in gear using the battery. This has worked for me in the past, however, not this time. Other than tearing it apart, is there some other method that might work.
Larry806
09-05-2007 08:43:43
 Re: stuck clutch plate in reply to nuley, 09-04-2007 14:47:18
I have a 300 backhoe that sat for years . The mice got in to the clutch housing and made a real mess . I laid under it over 8 hours taking the clutch bolts out of the flywheel through the tiny hole at the bottom . I had 3 different wrenches . I could gain just a little more with each wrench . The last 2 were rusted so bad I used the air chisel on them . We had to chain the rear half and use a come along on the front. Also big pry bars to get it apart . I couldn't find a good core ,Clutch & Joint charged over 400 to rebuild that one . But I did tell them I wanted the best clutch they could make .
JRT
09-04-2007 21:33:37
Are you sure it is a single clutch plate? Some of those 310's had a double clutch plate that were notorious for sticking if the tractor set a long time. If they are stuck bad the only way is to split it. I had one stuck so bad, it was almost impossible to get the tractor apart.
caseman-d
09-04-2007 20:11:08
Clutch was stuck in my W-9, I engages belt pulley and let it run while I worked the clutch. It come free.
caseman-d
Roger (Mi)
09-04-2007 17:18:02
 This trick may work in reply to nuley, 09-04-2007 14:47:18
The following trick works well on Ford 9N, 3N, and 8N tractors to free up a stuck clutch. Loosen the bellhousing bolts so there is a 1/2 inch gap at the bottom between the transmission and engine. Start the engine, and push down on the clutch pedal. Immediately, the clutch disk will break free from the flywheel! Tighten the bellhousing bolts, and you're good to go.
Walt Davies
09-04-2007 18:30:33
 Re: This trick may work in reply to Roger (Mi), 09-04-2007 17:18:02
I not real sure but isn't the Case SC a wet clutch that wouldn't work to well if so.
Walt
Roger (Mi)
09-05-2007 05:57:42
 You're right about the SC in reply to Walt Davies, 09-04-2007 18:30:33
Yes, the SC has a wet clutch. If the bellhousing bolts were loosened on a SC, what an oily mess! At least there are a couple of side plates on the SC to get to the clutch. The 310B has none.
Walt Davies
09-04-2007 16:12:44
Remove a cover plate and using a brass drift and large hammer put pressure on clutch release then tap the edge of the pressure plate it should pop loose.
Walt
