Some Case 1030 sleeves have a flaw
Roger (Mi)
08-23-2007 16:31:02
There is a stress relief groove directly under the sleeve flange. If that is square cut groove, the sleeve will develop a crack in the corner of that groove. Then compression will leak into the cooling system and antifreeze will leak into the cylinder. Other sleeves are NOT square cut. The groove is a radius cut. There is no place for a crack to start. Sorry, don't recall if the good sleeves are TRW or Sealed Power.
jim handke
08-24-2007 05:46:35
 Re: Some Case 1030 sleeves have a flaw in reply to Roger (Mi), 08-23-2007 16:31:02
Dad and I both had 1030's that had sealed power sleeves installed. I still have an 830 with them in. Nary a problem with any of them.
